jroden
Aug 28, 2013Explorer
bradnailer wrote:
Rather than using molding, you can always use silicone caulking. To give the seam a good clean looking joint, mask above and below the joint, run a thin bead of caulking, smooth it out with your finger then remove the tape while the caulking is still wet.
brilliant, that's my plan many thanks
44,029 PostsLatest Activity: Jan 28, 2025
