keymastr
Aug 16, 2016Explorer
Once the leak is fixed you will need to get inside the ceiling and see if there is rotten wood. You also probably need to replace the floor. You can probably just cut a sheet of 5/8 plywood and put it right over the existing floor.
You got it cheap enough that you can do quite a few repairs and still be money ahead. Just make sure you inspect the inside of the ceiling and walls for black mold. It will make you pretty sick if not removed.
