RobWNY's avatar
RobWNY
Help with the towing math
Hello. I am a new member here and this is my first post. This is a question often asked on here and the answers that have been given are always helpful to those that have asked but I am having a difficult time understanding and figuring out whether my Tow Vehicle is ok with the Travel Trailer I purchased this past November. I know that the bigger heavy duty Tow Vehicles I could purchase would be better but will my setup work and how much wiggle room do I have for gear (How much weight can I safely add to the Trailer and how much additional weight can I put in the truck? I weigh 200 LBS and my wife weighs 130 Lbs.)? The Travel Trailer we purchased is a 2014 Heartland Trail Runner 27RKS and the truck I have is a 2012 F150 with Ecoboost. it does not have the Max Tow Package and has the 3.55 rear end. Below I have added the specs of both the Travel Trailer and the Truck. At least as much info as I could find. Unfortunately, I don't have a weigh station close by either as some have suggested should be used to get actual weights of truck, trailer and both combined. Thanks in advance for any information that will be helpful.
Travel Trailer Specs
Dry Weight 6,442
Hitch Weight 500
Width 8'0"
Height 11'2"
Length 33'5"
Axles (2) 3500
Tires ST205/75R15-C
Fresh Tank 47 Gal.
Gray Tank 70 Gal.
Black Tank 35 Gal.
Propane (2) 30 Lb Tanks
Awning Length 17'
Cargo Carrying Capacity 1698 Lbs
Calculated with the Fresh Water Tanks Full Cold 240 Lbs Hot 50 Lbs
Waste Water when tanks are Full 872 Lbs
GVWR 9000 Lbs
Truck Specs
The combined weight of occupants and cargo should never exceed 1486 Lbs
GVWR 7200 Lbs
Front GAWR 3750 Lbs
Rear GAWR 3850
GCWR 15400
Max Loaded Trailer 9700
