hondapro
Jan 01, 2020Explorer
GrandpaKip wrote:hondapro wrote:
I think your truck will safely pull that trailer. The question is will you like the performance of it? only you can answer that.
The 5.3 is not a powerhouse of a engine and the 3.42 gear is not the greatest towing ratio.
You will be slow in the hills and the transmission will be shifting alot,make sure you have a transmission cooler.
Since you already have the truck hook it up and see if you can live with the performance of it,if not it is new truck time.
My personal opinion is I think you would be alot happier with a 6.0 liter and at least a 3.73 gear.
Just wondering, are you speaking from experience?
I live in the mountains of Western North Carolina. I’ve pulled all over the area and have never felt the 5.3L was struggling. Just the opposite, as a matter of fact. Put it in tow haul and the tranny takes care of itself and the temps stay normal. Very easy to hit interstate speeds without flooring it or maintain speed going uphill.
As I stated performance of the truck while towing is a personal opinion. What may be good performance for you may not be for others.I tow with a diesel because I don't like the way most gas engines pull.
I do think his truck can tow his trailer safely.Is he going to like the way it does it. is a question only he can answer after he tries it.
44,066 PostsLatest Activity: May 13, 2026
