Two problems.
One is that your vehicle is not in line with the tt in the pic. The hitch head swivels when you turn, that's how it works, so if the tt and tv are not in a straight line the hitch head will be pivoted. When it is unhitched, put the stinger in the hitch head and move it side o side to see how it works. You can do it without the stinger installed but will need to hold the locking pin up.
As for it pivoting to the side when braking, you need to adjust your brake controller so the tt brakes engage slightly harder than the tv brakes. As it is now, the tt is not slowing as quick as the tv so it is pushing, causing the head to pivot. This is known as the "Hensley bump"
I guarantee when you are pulling down the road that all is in line and normal. Fix the above 2 problems and it will be straight when stopped too.
