Marcela wrote:
If there was a need for realignment with weight in the bed, you would notice this driving without the weight as what is called bump steer, and it would be noticeable, and it would scare you. Very little bump steer or toe movement with suspension movement is designed into the suspension. Some manufacturers do it better then others, Ford twin I beam pre '08 sucks more then most I have read. I know my new GMC ifs drives better then the '99 Ford ever did..
My twin beam 1 ton was great after I found the local truck dealer that had the rack and gear to “adjust” the beams.
My 2016 F350 came with bump steer whether loaded or not. Dealer has fiddled and twiddled and only makes it a little better or a little worse. Just can’t find good suspension folks anymore.
