- ggrant119ExplorerThat's what I love about RVers ... Everyone has been super helpful. My only complaint is most RVers think 1/2 Ton Trucks are only built for going to the grocery store. I understand if you drive it recklessly you will get into trouble but.. that goes with anything (pretty sure I've seen more then a few professional 10 wheeler trucks upside down in ditches too)...
- Wishbone51Explorer
ggrant119 wrote:
It is a lot for the truck but I stopped at the scales loaded up and I'm not over. I understand that some won't tow anything without a huge buffer and some will say I'm crazy... but I'm right at the limits. I've only drove 775 miles with it so far. After the hitch was adjusted... It wasn't uncomfortable for me, I read a lot on this and other forums and thought I might have made a mistake..but that not the case at all.
I stopped at a CAT scale and weight everything.
Unhooked Trailer on scale - says shipping weight is 7,785lbs - I filled half of the fresh water tank / filled both propane tanks and I loaded almost everything I'm going to load in the pass thru (tools / hoses..ect..)- Scale ticket said... 7,865LBS
I purchased a Sherline Trailer Tongue Weight Scale ($129) from etrailer.com because I knew I was going to be close. Printed TW says 1,065lbs - trailer was dead level on the scale it says: 819lbs
My truck GCWR is 15,500lbs - Truck (me, wife, child, dog)/ Reese dual cam hitch / Trailer on the scale ticket says: 14,420lbs
*note on the trailer ... we had it built with table and chairs - took away the dinette (don't think this matters much)
I'm never going to travel with fresh water tank full / waste water tank full. I don't have any plans to drive cross country - I'm comfortable with my choice.
I have a similar situation. Towing pretty heavy with a 1/2 ton (Nissan Titan) .. GWR of trailer (see signature pic) is 7200. My maximum towing capacity is 7500, and all the other weights (payload, TW, GCVWR, etc) checks out, but barely. Very comfortable towing and braking. I don't go faster than 55, mostly because of fuel mileage (I average 9 towing) .. I go up long or steep hills at 35mph in third gear though, as transmission temps rise.
Went across country and back (5 week trip) a few years ago without a single issue. That was my second ever trip towing a travel trailer. Learned a lot. At the beginning of the trip, other RVers were really nice and helped me out. By the end, I was helping others out :) - ggrant119Explorer
BruteForceNewYork wrote:
Just picked it up.. 2015 Cougar 33RBI
I'm never going to travel with fresh water tank full / waste water tank full. I don't have any plans to drive cross country - I'm comfortable with my choice. - Travels_with_YoExplorer
Calicajun wrote:
Saw you the Ram forum, easy to spot your truck and trailer. :) I'm at about 7,500 pounds loaded and have been getting 14 mpg towing 26 not towing. My only problem with the truck in the 4 point air suspension, there no way I have found yet to beef up the suspension.
You must have less aero-drag and possibly, California hills are smaller in Southern Cal :)
Side note: I don't know if you're familiar with another former resident (of Lancaster), Don Van Vliet, but he's a fav of mine :) - CalicajunExplorerSaw you the Ram forum, easy to spot your truck and trailer. :) I'm at about 7,500 pounds loaded and have been getting 14 mpg towing 26 not towing. My only problem with the truck in the 4 point air suspension, there no way I have found yet to beef up the suspension.
- Travels_with_YoExplorerCalicajun ....
You can read all the details on the Ram Eco Diesel Forum .... I'm RAM Fan :-)
We just did a round trip to Branson and back (from north GA) and it tows nice with the added Timbrens. The truck sits all the way down on the Timbrems with the tongue and bed weight so it's quite rough and bouncy going down the road, but not mushy like it was before. Loaded weight is about 6,000 lbs. Mileage varies between 12.8 and 13.8 mpg. Towed about 3,000 miles with it so far. Non-towing, the mileage is right up there with the best of them .. sedate cruising 26 to 29 mpg. - CalicajunExplorer
Travels with Yoly wrote:
Our new 2015 Eco Diesel and 2015 Fun Finder together at last :D
For a peek at the entire maiden voyage .....
Our Maiden Voyage - Winter 2015
Nice looking TT and truck. How do you like the way your truck tows the TT? I have a 2014 Ram Eco Diesel and tow a 6,200 pound dry weight TT. - Winterwolf227Explorer
That is a lot of trailer for that truck. How does it do ? What's the weight ? - BruteForceNewYoExplorerSweet setup....how does the F150 do with that trailer?
- BruteForceNewYoExplorerIt always amazes me that the dealerships don't do some of this correctly and/or give you good recommendations
ggrant119 wrote:
I will be making the adjustments to my hitch (will post photo when I'm finished) I assumed the dealership understood how to correctly install the hitch... but I'm glad I posted a picture and you pointed it. Thanks again !!!!
44,066 PostsLatest Activity: Apr 10, 2026
