Mike_Up's avatar
Mike_Up
High cost of caulk repairs
Well I broke down for the first time and had a sealtech test on my 1 year, 3 month Jayco Jay Flight.
SealTech test wasn't to bad at $115. What is expensive is the labor costs to repair all the leaks that it found. It found leaks on the front rubber roof to aluminum siding seam. 2 of the roof to floor corner seams, 7 clearance lights, a few on the roof, 2 cargo doors, and some I can't remember. Hours will be about 5.5 hours of labor plus caulk and shop supplies. Plus the SealTech test, it's about $700!
The writer showed me some of the obvious leaks where there was cracks or a hole. I just can't believe there was so many in only a bit over a year.
Plus my roof was black and they recommend cleaning it. Of course that goes with their hourly rate. They said the roof was unusually dirty and that it needs to be cleaned before additional damage.
So with everything, I'm looking at a bill between $800 - $900!!
Now these guys are not hoods, who are out to screw me. They have been very helpful and honest in the past. I guess I'm just shocked at how many leaks there are and how much it's going to cost.
These are the times I miss my inexpensive to maintain, Pop Ups!
  • With all the damage water intrusion can cause....Why doesn't everyone get the seal test and fixes prior to delivery ??? Once you drive off, it's your maintenance problem even if the factory didn't do their job.
    I have not thought of this before, but maybe on my next one I will.
  • Can't you do the caulking???
    Did they give you a list of all the leaks????
    Just asking!
