ib516
Jun 13, 2018Explorer II
Good point made above, repairs are almost always cheaper than payments on a new vehicle. I have a relatively high mile 07 Dodge/Hemi and it seems just fine. I changed all the fluids and inspected everything when I opened it up. It doesn't burn any oil, the magnets in the rear diff and trans pan only showed fine metal fuzz, and not a lot of it. Everything in it works (A/C, power windows, radio, etc), so I'm pretty happy. The body does show some wear and has some rust starting.
That said, its a 4x4, and I paid $7000 Cdn for it, which is about $5400 in USD. It's got 233,000 Km on the odometer, so that's about 140,000 miles.
After I bought it, I did the following, doing all the wrenching myself:
- Rotors and pads on all 4 corners
- Rear shocks
- Added Timbrens
- Changed rear gear oil
- Changed transfer case oil (ATF)
- Dropped trans pan and changed both filters, replaced 6L of ATF
- Rotated tires
- Fixed driver's seat cushion with some new foam
- Replaced the grill
- Replaced the turn signal lever (signals worked intermittently)
- Ditched the "cold air intake" and put OEM one back on
- Sprayed rustproofer in the body where I could get it
- Adjusted the door latches to reduce wind noise
All in all I think I have about $8000 into it, and I have zero payments.
I figure I should be able to get 200,000 miles (320,000 Km) out of it by looking after it, and it pulls our little Hydrid TT just fine.
- Rear shocks
- Added Timbrens
- Rotated tires
