kayco53
Jan 06, 2016Explorer
There is a bolt on the bottom of the leg.Take it out.The lower tube while slide out.Then you will see the rod that slides past the seals.It sometimes rusts.This is as far as you get with out special tools to access the seals.Tool is no longer made.But it is 2 pins welded to a pipe.
44,068 PostsLatest Activity: Jun 05, 2026
