- K_CharlesExplorerI'm another one that never uses grease.
- CavemanCharlieExplorer IIII don't use it either. But, I don't use a weight distribution hitch and I wonder if they don't put a lot more pressure in the ball?
I've heard of people using wax paper. It adds a little lubrication, does not attract dirt, and doesn't get you dirty. - 352Explorer III lube my balls on several trucks. At this time I am experimenting on several different lubrication methods. I will keep you updated
- ScottGNomadThere was a time when I didn't use it either and then I started getting this tremendous squeak from it with a tent trailer we had. I also saw one that had worn through the top of the female side on a construction trailer (left a piece the size of a quarter in the middle) and didn't like that idea.
Either way it's not the end of the world. - DutchmenSportExplorer
snowedin wrote:
Am probably going to catch flak for it but I have never used an grease or lube of any kind on any ball hitch of any kind. That included bumper pull and gooseneck hitches. I do clean off the ball if it looks dirty and clean the female side of the hitch assembly but that's all. It seems to me that the grease just attracts dirt. Have never noticed any excessive wear on the hitch components.
Ditto! - PAAKExplorerI do grease mine at the start of the camping season, but only a small amount. As everyone has said, it just ends up on the clothes. I check it before every hook up and maybe will apply a small amount if need be. As others have said, vaseline works, it just helps with friction.
- elivi8ExplorerI don't use it either. I used to use it but it gets everywhere. I don't notice any difference without it. I used to grease the WD bars but I don't do that any more either. It does make more noise but realistically you couldn't put enough grease on it to keep it quiet anyways. At least not for more than one trip.
- snowedinExplorerAm probably going to catch flak for it but I have never used an grease or lube of any kind on any ball hitch of any kind. That included bumper pull and gooseneck hitches. I do clean off the ball if it looks dirty and clean the female side of the hitch assembly but that's all. It seems to me that the grease just attracts dirt. Have never noticed any excessive wear on the hitch components.
- Dog_TrainerExplorer III also grease the ball before each tow. When cleaning the hitch ball also make sure to clean the inside of the hitch coupler there can be quite a build up there.
- ScottGNomadAny grease will work. This isn't a case where you need some special lube.
I started using Vasoline because it washes out of my pants easier :R
44,070 PostsLatest Activity: Aug 05, 2026
