_1nobby
Jul 10, 2018Explorer
Hitch Extender
I bought a 14" hitch extender today as I was in a tight spot a couple of weeks ago and almost took out a tail light:) Turns out....the extender REDUCES tongue and tow weight by 50%. Makes sense...
#1nobby wrote:With WD the ball becomes a fulcrum. When lift (tension) is applied to the ends of the bars, it pries the weight forward, to the TVs front wheels.SoundGuy wrote:
Air bags would fix that but of course won't transfer any weight back to the truck's front steer axle as will any weight distribution system.
I get the theory behind the WD hitch but I guess I'm not understanding it properly.
If, say, you attach your trailer and the rear of your truck sags....the WD will bring it back up providing the correct weight transfer.....then what does the self leveling suspension do, if not the same thing?
At the end of the day....all the trailer weight is still attached to your hitch point.
