stlsailorrv's avatar
stlsailorrv
Hitch pin or hitch lock?
The receiver on my 2014 Sequoia is made in such a way that lack of room makes it difficult to get the hairpin over the hitch pin.
One solution would be a longer hitch pin but I haven’t found one longer than the 4” of the current one.
Another solution would be a hitch lock which would be easier to attach and detach. However, I don’t know if those are made simply to lock the hitch in place while stored, or they are strong enough to use while towing your vehicle.
I’m not sure of a need for a lock for a lock’s sake. My weight distributing hitch is so heavy that I can’t imagine they get stolen often. And, I’ve seen hitch lock/coupler lock sets, but again, it seems improbable to me that travel trailers are often targets for theft. So, unless there’s more of that going on than I know, I’m thinking mainly about a solution that makes things easier.
If you recommend a hitch lock, have you had good or bad luck with a specific brand?
  • I use one like this in our newer Sequoia mainly because Ive had it for years and it fits the Sequoia perfectly. Ive considered getting a newer locking hitch pin but there arent many that fit the confided space around our receiver and this works fine.
    https://www.amazon.com/gp/product/B073X5FPFT/ref=s9_acsd_newrz_hd_bw_b1420t_c_x_w?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=merchandised-search-3&pf_rd_r=Y038RP6EYQY6BRQPHQT8&pf_rd_t=101&pf_rd_p=965aaa45-b745-5c1d-94ef-6332f7ac3172&pf_rd_i=15737391
  • I've had one like BurbMan identified in his link and like enblethen, I got it at TSC.
    I've been using it for 4 years now. My receiver is the 2.5 inch and my old locking pin wasn't long enough. My 2.5 receiver has the insert, so when my hitch is not attached, I use the locking pin to hold the insert in (and to keep it from getting lost or stolen). I also use the same pin when towing. Works very well, no failures after 4 years.
  • Suggest going to a place like Tractor Supply. They have hitch pins in various lengths.
  • I use one of these Master Locks or the same reason. I don't really need a lock, but I was after a receiver pin with square shoulders, not one of those bent J-pins that wears out the hols in the receiver tube. I had a similar problem with very tight clearance between the receiver and the 7-pin socket mount, but this works. I can hold the lock end between the side of the receiver and the socket, then insert the pin from the other end. I have easy access to the lock since it is at a right ange facing me.
    It's fated as a hitch pin, I've been towing with it for years.
  • I have a hitch lock that I seldom use because it is made poorly. You should be able to find longer pins since there are 2-1/2” and 3” receivers available.
