jmtandem
Jul 21, 2015Explorer II
The food chain goes like this, Hensley Arrow\ ProPride, Reese Dual Cam, then all the other hitches with integrated friction sway control, and finally an add-on friction sway bar.
If you have the money then go with either the HA or PP. I personally like the DC.
I think I would add to the top of the food chain the PullRite hitch: PullRite , Hensley, ProPride, etc. PullRite has a pivot point nine inches behind the rear differential. It does not project the pivot point as does ProPride or Hensley. It is actually there. Downsides is weight at around 400 pounds, a little expensive, and usually requires modification of the last couple feet of the exhaust. But the hitch works extrememly well. And it is not a friction based hitch.
44,071 PostsLatest Activity: Aug 30, 2026
