Trailer GVWR = UVW +CCC...so should be around 7600lb.
Looks like it's around 14.7% (780/5312) hitch weight empty which is right within the ideal 12-15% range when empty.
Assuming 12-15% hitch weight should be somewhere around 1000lb when loaded.
Is the 1320lb...the maximum hitch weight or the truck payload? If it's the truck payload (yellow sticker on the door frame shows payload), you are likely overloaded.
WDH does shift weight from the truck rear axle. It winds up on the front truck axle and on the trailer axles. A WDH will help a little with payload but it easiest to take it to a CAT scale to weigh it and see how much payload you have used.
