1ed's avatar
1ed
HITCHGRIP Carrying Tool
www.hitchgrip.com
click
Has anyone used one of these and if so what are your impressions. I have the Reese Steadi Flex WD Hitch and the head is 51lbs and hard on the back. Looking for solutions for moving the Reese around. Thanks Ed
  • I have it and like it. It isn't perfect but it does make carrying the hitch head around much easier.
  • Bobbo wrote:
    I have been using one for two years. If I lost it today, I would have another on order tonight.
    It keeps grease off of me. It lets me carry the hitch, easily, at the balance point. While it doesn't make the hitch lighter, it makes it easier to manipulate.
    Same here - it makes the hitch so much easier to tote around. I'm 65, and anything that makes it easier to tote that heavy hitch head around is well worth the money.
  • The tool would add weight, so I advocate gloves without a tool.
  • Bobbo's avatar
    Bobbo
    Explorer III
  • I have one and it's OK for actually carrying the hitch. It does not make it lighter at all. 51 pounds will still be 51 pounds.
    The problem is, on my (use to have) when attempting to insert the shank into the receiver hitch, the hitch grip would hit the bumper of the camper before the shank even started to be inserted into the receiver. I'd still have to drop shank and ball to the ground and lift it with both hands to get the shank in the receiver.
    I stored my hitch and ball in my pass-through in the camper. There was not enough door clearance height to get the hitch and the hitch grip through the hole. Besides, handling that weight with one hand was a bit for me and that was a few years ago. Here again, set the hitch on the ground and I'd lift it from the ground to inside the pass through with both hands.
    Depending on where you store it, you may not have this problem.
    The short distance from the back of the truck to the camper pass through (what 10 feet) was not worth the hassle of wrangling the the hitch grip.
    However, when I got the fifth wheel and I pretty much retired the WDH, it was nice using the hitch grip to carry the hitch head and ball some 200 feet from my garage to the shed.
    Would I ever buy another one. Absolutely not! Should I have purchased it the first time? No However, if you have a shop and move multiple hitch heads around from one vehicle to another, and swap them back and forth, and have to carry them a distance, then yes... I think they are great!
    Yea, the hitch grip did not make it any lighter, it only balanced it making it a bit easier to carry with one hand.
    If you were in my neighborhood, I'd give you mine.
    I kept a plastic grocery bag over the hitch ball to keep grease from getting all over the hitch grip too. I think in the photo above, that was a paper shop towel.
  • the only advantage I can see is you may stay cleaner by lifting with the tool. The hitch still weighs the same, plus weight of tool, that has no mechanical advantage IMO. I've no experience with one though.
    Jerry
