lawrosa
Mar 15, 2018Explorer
Best deal with mt 50 meter and temp sensor..
https://www.amazon.com/dp/B071XP39BK/ref=twister_B077ZN5SP5?_encoding=UTF8&psc=1
Solar racking is just mounts for the trusses. Then two rails. Solar panel lays on the rails. And clips hold the panels to the rails. So the rails always stay there. But you can remove panel for cleaning roof easy.
Mount the rails though so they slope up from front of RV. Puts the panel at a slight angle for wind deflection.
So you will need higher mounts for rear vs front if you know what I mean..
And I was going to run the wire from the panel over the roof edge and down the awning track. Then down under the trailer. Whear the wire comes out of awning track at bottom I was going to use some electrical wire cover..
