westend
Mar 22, 2018Explorer
You don't state the size of the inverter and that will dictate your highest current draw and your largest cable size. Most inverters have wire sizes applicable to the current. Your panel won't develop more than about 20 amp charge current so the smallest sized wire from controller to battery would be 12 AWG. 36V and maximium current from the panel would indicate 12 AWG also to be adequate.
FWIW, since I decided to have the least loss of harvest possible and had to order 100' of 4 AWG, I decided to use it for most of my runs. I bought the cable at Waytek Wire, they are local to me. A good online seller that will make custom wire pieces is Genuinedealz.com.
Here is a wire gauge calculator: Calculator
