monkey44
Jun 21, 2013Nomad II
Honda 1000 ?
If all we want to do is charge one/two batteries (Gr29,), is the 1000i enough. Prefer not to go 2000i, even for only $200 more. I'm concerned about size and weight, somewhat ... and will never ca...
DanoT wrote:
This may not apply to the OP, but here is what I do: I mostly use my TC in winter at ski area parking lots. My 18k btu propane furnace will draw my AGM battery down in about 24 hours. It takes about 6 hours with the camper plugged in to my Honda 2000i to fully charge the battery but only if I turn the propane heater off and switch to a 900w electric heater while the gen is running and I also have enough power to charge computer battery and run a ski boot drier.
If I try to run the propane furnace and try to charge a low batt. at the same time, the fan in the propane heater will draw down the battery almost as fast as it is being charged. If I used a Honda 1000 gen then I would not be able to charge the batt. and run an electric heater.
