- shum02Explorer
edbehnke wrote:
get the cheap generator but don't run it next to me. i've had several experiences where rvers get a noisy generator and want their neigbhor, me to listen to it for hours.
and, at times, some 2K hondas will start and maybe run a 13.5K a/c but not very well and it is noisy.
I'm guessing you think it's the open frame model?? You are wrong. It's Champion's inverter model and if both units where powering a 13.5k btu a/c next to you you would want the Champion doing it not the screaming Honda.
Regarding can they be paralleled? Not sure on that.
Their website Champion 3100 Inverter - edbehnkeExplorer IIget the cheap generator but don't run it next to me. i've had several experiences where rvers get a noisy generator and want their neigbhor, me to listen to it for hours.
and, at times, some 2K hondas will start and maybe run a 13.5K a/c but not very well and it is noisy. - scottzExplorer
mkirsch wrote:
NOTHING is as quiet as a Honda, period.
You can stare at that cheap knock-off generator all you want, tilt your head to one side, and say, "It's not that loud," but you're in a state of denial.
The real question is, do you care? The cheap knock-offs are still not as loud as a contractor generator by a long shot. If you're one of those people who has to have the generator running **ALL** **THE** **TIME**, you better invest in the Honda.
Owners of the Champion 3100i (and 3100w) seem to love them, in fact love them more than their Honda 2000i. - hedgeExplorerI had a Champion 2000 Inverter, it would not start my 9200btu a/c. I replaced it with a Honda 2000 and it runs it in eco mode.
I believe Champion is a bit optimistic with there ratings. I was happy with the Champion up to this point, it never gave me any trouble. I do like the 'footprint' of the Honda better too. - scottzExplorer50% more power
Similar noise rating?
Standard 30amp RV connection
Remote start
Great Support
Only $200 more
Give me the Champion all day long!
I wish this was available when I bought the Yamaha 2400i. - exhaustipatedExplorerI've got two Champion 2000w inverter generators that I parallel together if I want to run the air conditioner, but I usually take one of them along with me to power up anything I need to use. I've compared both the Champion and Honda and the Champion is just as quiet as the Honda at a fraction of the cost. I only use it sparingly when I need to so as not to bother any other neighboring campers near by. When I boondock and no one's around me I'll fire it up for longer periods of time.
- timdan94ExplorerI have the champion 3100 and have had people at the campground say how quiet it was. It starts my 11000 btu ac on the eco mode. It starts on the first pull and is very easy on gas.
- tvman44ExplorerChampion! :)
- JayGeeExplorerIs 3100 watt all you will ever need/want? At some point you might want to parallel and get more power. Can you parallel the 3100? The 2k can be hooked to another 2k.
Noise wise, depends a lot on where you will be using it. If the noise don't bother you and you will not want to increase your power I would go with the Champion. - BumpyroadExplorerI think the comparison should be with a honda/yamaha 2600 or so one that would run an AC. yep, a honda 1000 is quieter/lighter, etc. but won't run anything.
bumpy
44,066 PostsLatest Activity: Jul 25, 2018
