germanic333's avatar
germanic333
Honda EU Series Inverter Generator
So this is along the lines of my boondocking question but specifically, about this generator. the question is I am looking into buying this generator> Honda EU Series Inverter Generator — 2000 Surge Watts, 1600 Rated Watts, it says Inverter Generator, so then can I bypass the purchase of an Inverter? will this generator work in the same way? ie ( change my 12 volt bat to 120 at the plug in on the genny? so the question is do I need both and if so why, or can I just use this genny? thanks all, getting closer to boondocking..
  • The internal "inverter" is just a fancy voltage regulator on the generator head, that allows the motor to run at different RPM for light loads, saving fuel. It's not an inverter like you would have in an RV or truck, and cannot be used separately from the generator.
