- 9245 will max out that 1000va Honda if the battery is low. No need to measure.
So you will see some drop in voltage as the Honda is loaded up but all looks normal. - SCVJeffExplorer
KD4UPL wrote:
my standard is 122.5, and has been for years.
That's very normal and acceptable voltage. Most homes have voltage from the power company anywhere from 120 to 125v.
As has been shown, it's within spec.
The power companies have been jacking up the voltage for years trying to get more power thru existing lines. The standard used to be 110v. Then it was 115. Now it's 120. It wouldn't surprise me if they raise it again eventually.
The voltage on the Honda is exactly where mine is when unloaded. - afraid_of_bearsExplorerThanks all!!!!
- KD4UPLExplorer IIThat's very normal and acceptable voltage. Most homes have voltage from the power company anywhere from 120 to 125v.
The power companies have been jacking up the voltage for years trying to get more power thru existing lines. The standard used to be 110v. Then it was 115. Now it's 120. It wouldn't surprise me if they raise it again eventually. - TucsonJimExplorer IIThe best way to measure the amps is to have an amp clamp you can hook to your multi meter. I wouldn't worry about it though. As long as your batteries are charging and your voltage is within spec, you're good to go.
- afraid_of_bearsExplorerI'm not sure how many amps are going into the battery. How do I figure that out? The trailer has a Progressive Dynamics 9245 converter. I'm going to assume that means 45amps when running flat out. My batteries were not dead, so I would assume that there were far fewer amps being pushed. The generator was basically running at idle speed.
Thanks for the responses so far. I feel better knowing things are as they should be. - 125 is normal. It will sag a bit as the load increases.
How many amps are going into the battery? - TucsonJimExplorer IIYou had me doing some research on this topic. According to the American National Standard for Electrical Power Systems and Equipment (ANSI C84.1), the acceptable voltage for a 120VAC system is: 114 to 126 Volts.
Your generator is producing voltage which meets the specifications of ANSI C84.1. - afraid_of_bearsExplorerGot brave and used a multimeter. It gives the same readings.
TucsonJim wrote:
Sounds a bit high. Just to be sure, what are you measuring the voltage with?
One of those voltage meters from Camping World.
Clicky
It seems that the voltage in my house is 123. So, maybe the meter is a bit out?
44,068 PostsLatest Activity: Jun 21, 2026
