TucsonJim
Aug 19, 2013Explorer II
According to the spec sheet for this unit, the output voltage is 120V, 1000 Watts Max. It does not list any tolerance for this voltage. So, if you're seeing 125 Volts, you are running about about 4% over the rated voltage which is probably okay.
44,056 PostsLatest Activity: Mar 02, 2026
