iwski
Jun 25, 2014Explorer
Honda EU2000 or Companion?
I was able to try another person's Honda EU2000 generator with my air conditioner on my 2005 Arctic Fox 990 and it worked fine, so I think I'll get an EU2000 for myself. I'm trying to determine if it will be worth the extra $130 to get the Companion model. I never plan to get a second EU2000 to run parallel. As far as I can tell the only difference is the Companion model has a 30 amp plug and as a result you loose the DC battery charger plug (not needed for me). Other than plugging the camper in directly with no adapter needed, is a there any other benefit to having the 30 amp plug? The 20 amp household style plug will suffice as far as amperage because the generator is only rated at 13.3 amps. Possibly the adapter would heat up if I run the air conditioner using the 20 amp plug with adapter? Any other issues?
