SoundGuy
Jun 05, 2015Explorer
Huntindog wrote:
There is a mod that can be done on the Hondas to allow them to be run out of fuel like the Yamahas.
Not really a mod per se, just disconnect the 2-pin connector that feeds the Honda's common fuel / ignition switch ... when you turn the switch off to kill fuel flow the switch is electrically disabled from killing the ignition so the engine continues to run until it runs out of fuel. For occasional use just pulling this connector apart works just fine but for those that would want to do this regularly installing a simple toggle switch in the wires would make it much more convenient. I've disabled my first EU2000i many times and doing so works exactly as described but I've not bothered with the one I have now as I run it using only SeaFoam treated non-ethanol gas and run the genset every couple of weeks so fuel gum up hasn't been a problem for me.
I've owned 2 EU2000i gensets and there's no question the Honda with it's 20% larger engine offers much better surge capability than does the Yamaha EF2000iS. For any who doubt just how capable the EU2000i is there are several YouTube videos out there, this being one ...
Honda EU2000i (Over)Load Test
In another recent discussion it was also mentioned that the Yamaha EF2000iS is NOT recommended for use with the Progressive Industries EMS units and warranty coverage for any damage caused when doing so will be denied by the manufacturer ...
Progressive Industries EMS / Yamaha EF2000iS Disclaimer
Obviously one could side step this issue by disconnecting the EMS or bypassing it when powering from the genset, or installing a transfer switch, but I'd still consider this a drawback to the EF2000iS compared to the EU2000i since there's no similar disclaimer for Honda's EU2000i. However, even for those not using any type of electrical management system OR for those who do but bypass it when running on genset that still doesn't address Progressive's main concern about the EF2000iS ...
"Please be advised the Yamaha Generator Model EF2000iS does not generate enough start-up current which causes the unit to overload. The generator then puts out non-true Sine Wave power. Progressive Industries units are designed to operate only on a True Sine Wave."
Presumably Progressive wouldn't make this statement on their own website if they'd not investigated thoroughly, the point being that if the EF2000iS, which is advertised by Yamaha as a true sine wave inverter, in fact does not generate true sine wave under ALL circumstances then I'd be really concerned for some of the electronics in my trailer. Based on this alone the Honda EU2000i would seem to have the clear advantage.
