rockhillmanor
Mar 10, 2016Explorer II
mountainrivers wrote:
Thanks for that information. We would also like to connect water and sewer if possible. Have you considered that, and, if so, how did you connect to the sewer?
Find your sewer line and add a 'clean out cap'. That is where you would hook up your sewer hose from the RV. Many residential sewer lines will already have one in place.
Only thing is, is that doing so is illegal to use for an RV on your property. Adding a clean out to your sewer line is legal but not for use for the RV.
Done under the cover of night works for most. BUT you seriously need to find out if you even can park the RV on your property.
Your worst enemy will be your neighbors turning you in if they see you are hooked up to your sewer line.
44,066 PostsLatest Activity: Jul 25, 2018
