dodge_guy
Dec 01, 2014Explorer II
Spanousis wrote:
So a 3/4 ton will fix the problem? Thanks!
No! Then all you'll have is an improperly setup 3\4 ton truck! First you need to make sure you have the proper tongue weight and that everything is setup for towing. Make sure all air pressures in the tires are up, air up the truck tires to their max rating (not what is on the door! That pressure is for a nice ride, not towing). Check all your weights by going to a scale and weighing everything. Once you have all that then you can make the determination on whether you want or need a new truck!
A lot of people come here and go out and buy a HD truck and say how much better it tows!........well it should because now they just have a HD bandaid.
