MrPhelps
Dec 02, 2017Explorer
Very glad you are back safe.
I too am very interested in the pictures and description of your truck's handling of the camper on the road back. However, now that you have experienced your maiden voyage, I'd like to ask some functional questions.
In advance of the picture posting I have two questions:
Q1. I was concerned with the Host designed passenger side gray tank under camper pvc plumbing routing, dump valve location and the mechanism to get the tank dumped at the rear driver side location. It looked somewhat complicated and there is concern it could become an issue over time with road contamination . It also seemed that the camper would need to be positioned to :
A. first to dump the nearly eye level black tank and then,
B. pulled forward to dump from this somewhat complex gray tank lower dump location.
Or, is the larger black 4" PVC diameter pipe is for a shorter separate gray dump hose and a longer separate black dump hose is required for the other tank stored somewhere else ?
So... What are your comments about the dumping process given the locations on this camper and are there any indications that grime or dirt might impact the life of the gray tank dump mechanism?
Q2. The camper I looked at was unpowered so I could not test the slides. I'm curious about the need to fully open the driver side slide in addition the passenger side slide to minimally access the bathroom. It looked to me like the driver side needed to be fully extended for access, thus limiting somewhat impromptu side of the road stops. I'm sure on the trip back there was at least one experience with this.
Again, Welcome back to the South and thanks in advance for addressing my questions.
Mr. Phelps
Mr. Phelps
