DaveInVA's avatar
DaveInVA
Host Everest or Cascade owners?
Greetings,
I'd appreciate any feedback you can provide good or bad on your experience with Host. Both campers are amazing from what I can gather online.
How has having the black tank located in the slide? I assume it is independent of the grey water tank, so how do you flush your line after dumping your tank?
What is your average weight when loaded up? How does the truck handle under load?
Thanks for your time.
  • Thanks Bedlam!
    Have you experienced any issues with your TC that tend to occur on other brands or do you believe that Host is priced at a level where they have not cut corners that other brands may to save weight and cost?
  • The toilet and bath sink dump into the black. The shower and kitchen sink go into the gray tank.
  • The sink is dumping into the black tank, in the slide, under the couch or dinette. Its more than a enough tank capacity for black.
  • The tank is similar in my Mammoth. There is an external black tank flush next to the dump port. You can run water from your bathroom sink via pump if there is no water available at the dump site.
    After dumping your black tank, move the hose to the gray dump and repeat. This should get most the solids out of the dump hose.
    The Mammoth and Everest will weigh about the same. Expect about 4500-5000 lbs dry based on how you option it. The Cascade is a foot shorter and should be a little lighter. Mine is over 6000 lbs when loaded and filled, but my 5500 handles it without any modifications even when I add an additional 1000 lbs of trailer tongue weight.
