yblaw
Oct 19, 2017Explorer
We live in SoCal and often camp in the desert. If heat is an issue in the cabover area of your Mammoth, check out www.swampy.net They make the "Little Swampy" evaporative coolers. We bought the K-2 Model for $299 delivered. We cut out a piece of 1/8" masonite to fit the passenger side window in the bedroom, cut a 4" hole in it, attached a 4" duct and flex hose, and set the cooler on the slideout ledge above the refrigerator. It really works well. If you live in humid areas where "vap" coolers don't help much, it doens't need to have water added or use the outside air; works fine as a fan to circulate the A/C flow in the bedroom.
44,056 PostsLatest Activity: Nov 19, 2013
