Steve_S1
Dec 02, 2013Explorer
Hot air out the side
Hi I was just wondering if the hot exhaust from the furnace was just wasted heat or is it just stale exhaust? It sure seems to be a lot of heat coming out of there!
BurbMan wrote:CGXterra wrote:
I wish they could redirect that exhaust to the tubes and tanks that are exposed to the cold. You'd think they could wrap the exhaust tube around important stuff and have it go out somewhere else. I doubt I'm the first person to think this and I'm sure there's a perfectly good reason why it's like it is.
That's how they provided cabin heat on the old VW's with air cooled engines....since no coolant meant no radiator or heater core.
Instead VW used an air-to-air heat exchanger where outside air was run through a jacket around the exhaust manifold and warmed before being blown inside as heat. Rust was always an issue, and when you could smell exhaust inside the car it was time to replace the heat exchanger.
