TowBo's avatar
TowBo
Hot brakes and Tall trailers
I have a small light tow rig. With our weight dist. hitch with sway control, it tows amazingly well. It almost drives like I'm not towing at all... until I look at the MPG... The issue I have is with the brakes on our single axel, 19ft, 2015 Jayco Jay Flight (baja). I use the p3 brake controller. We tow in the Pacific Northwest and often encounter steep hills, sharp corners, and wet conditions. We can smell the brakes working. The wiring looks good underneath, but the wheels on the Jayco are definitely getting hot. We are beefing up the brakes on the tow rig, should we consider upgrading the trailer brakes as well? Am I not adjusting the P3 correctly? We wont be changing tow vehicles for a couple of years when our other vehicle is ready for a replacement. It just isn't in our cards right now, sadly. Here is my current set up. Its a 2016 Sorrento rated to tow 5,000 lbs. My TT has a gvwr of 3,800, but we have it loaded @ 3,400lbs. The other issue may not be one and someone with more experience can weight in. We have a low tow vehicle and the TT is significantly higher. The Baja edition we have comes with a higher suspension. Do you think drag is an issue? The other issue is adjustments with the hitch itself. Its really close to level but not perfect. Has anyone safely lowered a TT? Would you recommend it?
