ttavasc wrote:
That looks like a 195RB Baja - if so we have the same year and model. One of the problems we ran into early on with it was sticky brakes which caused similar situation to what you are describing. In my case there was a chalky sort of build-up accumulating where the edge of the shoes contact the back of the drum as well as various places on the brake magnet arm. I wire brushed all those areas clean and now use CRC Brake and Caliper Grease on all those touch points every year when I re-pack the wheel bearings.
I wondered if the brakes might be sticking. Thanks for the heads up. It helps to have others who know what to look for. It is the 195rb baja. We just picked ours up a few months back. How is yours holding up? Do you like it?
