All three conductors have to be used coming from the house 120VAC receptacle. This is the only place the trailer is grounded to earth ground.
If you are receiving a slight "shock" then the green wire is probably not connected all the way to the trailer. Sometimes the ground prong has been cut off of the adapter with only two wires hooked up. Another possibility is the 120VAC receptacle in the garage you are plugged into. The GREEN WIRE may not be connected on it.
What works for me and the only safe thing to use when hooking up to the house 15A/20A receptacle is a good HD 10-gauge (10-3) extension cord. A 12-gauge may also work but the 10-gauge would be the best choice. Then on the end of this 50-foot extension cord you would use a good quality RV30A-15A "DOGBONE" 18-inch long adapter (WALAMRT)
I will not use any of the small black molded RV30A-15A adapters as they always get hot on me after being used just a short time.
I would use one of these circuit testers (LOWES) and if the two YELLOW LIGHTS come "on" on the bottom then the 120VAC circuit is good to use. First I would plug the tester into the receptacle in the house. Then I would connect the 50-foot extension in that receptacle if it tested good and then use the tester in the other end of the extension cord. If that tested good then you can plug the RV30A-15A "DOGBONE" adapter into the end of the extension cord. Then you can plug your 30A three prong RV shore power plug into the adapter.
You have an UNSAFE situation on your hands if you are being slightly shocked when touching your trailer standing on the ground. I would UNPLUG IT and get it FIXED right away. Remember its not just you being shocked - your kids and your animals will get shocked as well.
Roy Ken
