NJRVer wrote:
Just to add. We had a hot skin condition that was caused by the electric heating element in the hot water heater.
Hot water heater had been energized by the dealer with no water in it which caused the element to burn out unbeknownst to us.
When the tank was full of water and we turned on the electric element it caused the hot skin.
I've been doing experiments along this line, and there's two pieces of information to consider.
First, if you have a properly grounded RV via the shore power connection, an electric hot water heater element with a pinhole leak WILL NOT cause a hot skin condition to exist. Of course, if you have an open safety ground due to a miswired receptacle, broken power adapter, or open ground in your extension cord, then certainly the electrical leakage in a compromised hot water heater element will instigate the hot-skin condition and can raise the voltage up to 120-volts with approximately 2 amperes of fault current available. This is enough current to trip a GFCI, but not enough to trip a 15 amp circuit breaker. I know this because I'm running a test right now using a rusted-out hot water heater element inside a visible hot water heater tank where I'm testing for hydrogen gas generation.
Secondly, a hot water heater element with a pinhole leak will create a steady stream of hydrogen gas bubbles, and quite possibly a matching stream of oxygen gas. How much oxygen that's created will depend on water chemistry, with high salt content creating chlorine gas and other stuff. The key point is that there will be either HHO (Brown's) gas created, which is highly explosive, or a combination of Hydrogen and some other corrosive gas which can rot out the inside of your hot water tank. I've been collecting a few cubic inches of Hydrogen and ??? gas per hour, so a week's worth of operation without turning on the hot water faucet to purge the gas could fill up your hot water heater with a significant amount of gas. I'm not sure just how explosive or corrosive this gas will be just yet, but that's my next experiment.
I'll be writing articles about this as soon as I gather some useful data.
Mike Sokol
