- SCVJeffExplorer
smkettner wrote:
and once done shuts off. Its a thermos...
Operates on 120V household current
- Rating: 110-120V 60Hz, 12A at 20°C
What does a coffee pot take? Sounds like it takes 12 hours to heat. - SCVJeffExplorer
Lantley wrote:
I guess no one here has ever owned an electric only portable spa? They're built to plug into a 15-20A 115vac outlet.SCVJeff wrote:
Those things typically draw no more than a coffee pot. Disposal of the water is a different issue for sure
You mean no more than a 250 gallon coffee pot;) - RedRocket204Explorer
CKNSLS wrote:
If more people do this electricity will be metered every where.
So if your entire rig is not drawing much electricity anyway... what is there to worry about? - LantleyNomad
You mean no more than a 250 gallon coffee pot;) - BulldawgFanExplorer
Executive wrote:
Problem I see with these in a campsite is what you do with the water when you're ready to leave. I don't think I'd want to camp near you if you're dumping 250 gallons of treated water in your campsite just as you're pulling out...don't think I'd want you next to me either especially if I was downhill...just sayin.....Dennis
They have a drain outlet that you hook a garden hose to. Therefore you can direct the water off the campsite and away from neighbors. - Operates on 120V household current
What does a coffee pot take? Sounds like it takes 12 hours to heat. - CKNSLSExplorer
Link please! - I want one for camping in the snow :B
- SCVJeffExplorerThose things typically draw no more than a coffee pot. Disposal of the water is a different issue for sure
- LantleyNomad250 gallons is a lot of water. It won't take long for CG owners to ban hot tubs
44,056 PostsLatest Activity: May 04, 2014
