Massey16's avatar
Massey16
Hot Water From Cold
We got out camping for the first time this year this past weekend. As such, I ran water through the camper to push out the antifreeze I put in last fall. Then, I switched the valves to fill the hot water heater. After it was full and heated, I noticed a leak from the plug that I couldn't fix by tightening. So, I isolated the hot water tank without turning off the external supply, fixed the leaking plug with plumber's tape, and turned the water back on to the hot water tank. Afterwards, I have noticed that when we turn the cold water on at the sink in the kitchen, we get cold initially, then extremely hot water for a short period, followed by cold. Why am I getting hot water out of the cold? Have I damaged something?
  • Where is the check valve located? Hard to replace?
    Why would it go back to cold if the check valve is bad?
  • Bad check valve maybe.
    More information about exactly what you have will result in the best answers.
    What RV?
    What water heater?
    What style bypass kit?
    What plug/fitting did you R&R?
