mackenziejkExplorerMay 12, 2014Hot water heater drain plug leakingHi i have a 2005 areolite 215 cub, and when i put water in my trailer, it starts to leak at the drain plug, i have replaced it and put the tape on it and still leaks, when water is in the water heater...Show More
mackenziejkExplorerMay 14, 2014If I can't stop the drip will it be okay if I just bypass the water all together? I a, able to with valves.
Related ContentWater Heater Leak on start up.Atwood water heater problemWater Heater Replacement RecommendationsSuburban SW12DEL Water Heater On/OFF switch melts???Tankless water heater
