adairlb's avatar
adairlb
Hot Water Heater Not Working
We took our TimberRidge 250 RDS out for the first time in a couple of years and the hot water heater wouldn't work (tried both gas and electric). It fired up on gas but went right out immediately. Is there a bypass valve that is closed from when it was winterized? I have a feeling this is operator error, but can't figure it out.
  • Hello.....OP
    Are you still having problems..
    No feed back,.........WHY?!
  • Bypass is part of the water system.
    Cold water inlet valve on bottom of tank......S/B OPEN to allow water into water heater tank
    Bypass valve connects cold water line with WH tank hot outlet line....S/B CLOSED so cold water doesn't flow into hot water plumbing lines
    Hot water outlet valve (IF you have one...lots don't just have check valve) S/B OPEN
    Electric element turned on w/o water in tank......burnt element will need replaced (they are immersed in water which keeps them from burning out)
    Propane.....fired up then shut down immediately. Wasn't because of no water in WH tank.
    Water heater tank would need to reach 130*F/140*F before normal t-stat would shut down propane....that would take several minutes with tank empty
    Immediately shutting down is usually due to 'flame proof' failure.
    Flame needs to engulf spark electrode when lit....it then sends signal to circuit board that flame is lit and keeps gas valve open until temp set point is reached then t-stat opens and gas valve closes.
    Some of usual issues with flame failure
    Electrode out of position
    Bad ground...loose/dirty ground screw
    Loose/dirty spark wire connections
    Cracked ceramic on electrode
  • If it was bypassed and had no water and you tried to heat with electric you more than likely fried the electric element. Check for spider webs or other obstructions in your gas jet.
  • Yes, there is normally a bypass valve at the waterheater that is closed off - this is so the anti-freeze does not actually go into the waterheater.
    I did this once before myself... easy to resolve.
