KFCCaravan's avatar
KFCCaravan
Hot Water Heater Question
Hi There
Quick question for the exerts:
I have a 2014 Coachmen Clipper - Unsure exactly what hot water heater I have. It's definitely a 6 gallon propane unit.
Anyway, I winterized my water system (including hot water tank drainage) a couple of months ago. I've since been using the trailer in my backyard for side projects and left the batteries hooked up and the propane hooked up and shutoff valve open to run the furnace intermittently when needed.
Yesterday I went to the trailer to grab something and noticed that my water heater switch was turned on and the status light illuminated red. I must have bumped the switch the previous day into the on position.
So the question is: Did I ruin my hot water heater? I obviously can't test it with the water system winterized.
Thanks!
Brett
  • 352 wrote:
    If you already have hot water why in the world would you even need a water heater???????
    Lol :S
    I re-read my post several times like an idiot trying to understand your question before it came to me.
    I was waiting for someone to say it lol
  • If you already have hot water why in the world would you even need a water heater???????
  • KFCCaravan wrote:
    I'm going to look for that switch at the tank. Thanks for the suggestion.
    If you're referring to Dutch's post, that switch (on my coach anyway) is only for electric. And yours is not electric. But hey.. they're all different!
  • KFCCaravan wrote:
    It's for sure a propane only heater so no electric element to burn out.
    Keeping my fingers crossed until next season when I (attempt) to fire it up for the first time.
    Brett
    If it's propane only, there will not be a switch at the tank. The only switch will be the one inside the camper. The switch at the tank is for electric only.
  • It's for sure a propane only heater so no electric element to burn out.
    Brett
  • KFCCaravan wrote:
    my water heater switch was turned on and the status light illuminated red. I must have bumped the switch the previous day into the on position. So the question is: Did I ruin my water heater?
    That red light in my coach means the DSI is trying to light. Maybe you got lucky and it never ignited.
    I don't know if you ruined it. It's lucky it didn't burn to the ground. Depending on how long the switch had been on, it may have exhausted the propane supply and is trying to light. Do you have any propane left?
  • Do you normally run your water heater on "Electric" or just propane? (Or both).
    If propane, as stated above, just a reset and it will be ok.
    If electric, you burned up your electric heating element.
    Your water should have an electric on-off switch at the tank. As a double precaution, when there is no water in the tank, you should always flip that switch to off. Then, if the switch inside the camper gets bumped (like probably happened to you), the heat element will not come on.
    So the thing you need to figure out first, was your heater on propane only, electric only, or both? Go from there.
  • If your WH is propane only, it may have tripped a reset, if it over heated. If also electric, and electric switch on, you would have burned out the element, which can be replaced.
    Jerry
