Nvr2loud
Aug 12, 2013Explorer II
The flame will also travel a lot further through the tube if the water is very cold. Once the water is heated a little bit, and therefore the burner tube is heated a little bit, the flame should shorten up a little.
It is worse when an obstruction is in the tube, but you've already got that covered.
44,056 PostsLatest Activity: May 04, 2014
