billyray50's avatar
billyray50
Hot water tank propane leak
I noticed a propane smell in TC this morning when I went out into the camper. Did a leak check and found the brass fitting was leaking. Here are pics. Bubbling was more intense before I got camera ready. Tried to lightly tighten fitting but already as tight as will go. Is there a quick fix that I can do or do I have to take TC in for service. Emailed Adventurer also, waiting on reply.
  • That is a flare fitting. I would loosen it up (using two wrenches) and check for damage on the flare where it contacts the fitting. Before you start, mark the fitting so that you can compare the 'before' and 'after' location of the nut. If there is no visible damage then re-tighten... again using two wrenches. and see if the fitting is actually tighter when you are done.. it should be. Then re-check for leaks. Oh.. you must turn off the propane first of course!!
