Old-Biscuit wrote:
We use Dawn Dish soap and same TP we use in house.
Special RV TP is expensive junk and not needed
Ditto.
If you are planning on being at a park/campground that has water hookups, and plan to use it connected to the RV, get a piece of white hose and a water pressure regulator (both can be found at Wal-Mart, in the RV section, which is near the automotive section)
Connecting a water spigot directly to the RV "city water" connection will over pressurize the water system, and my rupture water lines.
Any tip in that regard, when I connect to city water, I ALWAYS turn OFF the water spigot when I leave camp unattended.
If I am using the water pump/tank, I always turn off the water pump when I leave the rig unattended.
