- Ed_GeeExplorer IIMy panels are mounted flat on roof .... mounting brackets fastened to roof with 3M double sided tape. Mount brackets have option to add tilt bar for the panels if I am parked for extended period.
- Yosemite_Sam1ExplorerThat's the reason why I did not mount mine on the roof.
Besides, I want my campsite under trees and tucked in the forest -- I can move my panel and need not the RV. - CA_TravelerExplorer IIII read that 7 times on the roof is the average for panel adjustment. Most just add one additional panel and they are good to go.
- jdc1Explorer IIWho wants to climb up there to move it every hour? You'll end up wrecking your roof eventually (retired general contractor). You'll get 6 hours+ of great sunlight even in winter if they are mounted as they should be.
- 2oldmanExplorer II4 two-bolt brackets per panel. Nope, just two directions.
44,056 PostsLatest Activity: Aug 03, 2021
