jmtandem
Oct 27, 2014Explorer II
First. I currently have a 2005 Yukon with a factory tow package installed, a 5.3L V8 engine and a 3.42 rear end, 4 wheel drive TV. It is rated at 7500 pound tow capacity.
It depends in part on three things. How comfortable are you towing a bigger trailer; where do you want to go as some older state and federal campsites are smaller than the bigger RV parks or newer campgrounds; and how much can your tow vehicle haul. If you have a 7500 pound tow rating that is provided by the manufacturer that is the max weight for your vehicle to tow. Some advocate the '80 percent rule', or going up to only 80 percent of the 7500 rating. In the real world no manufacturer provides an eighty percent rule. If they say it will tow 7500 pounds that is the value. Good luck.
44,056 PostsLatest Activity: Nov 19, 2013
