JBinOR
Apr 12, 2014Explorer
westend wrote:
If a guy would lengthen some of that wiring (and why not remove those Scotchlok connectors?), you could install panels across the sides and bottom with the wires behind.
Interestingly, I was doing this exact same thing this winter. I was about to order a custom made door before seeing all of this. I'll order one from Jayco too. I did not have as many wires as there are here, and I was about to lengthen the wiring, just like is suggested, and I noticed that all of my wiring had a ton of slack in the walls and floor. So I just gently pulled some slack and threw in some luan.
