Terryallan
Jan 13, 2014Explorer II
Wondering. Did you run Antifreeze thru the water pump? IF not. It probably froze as well. The pump being frozen, was probably damaged, seals cracked, and allows antifreeze to drain into the fresh tank.
I thinkin, IF you didn't run antifreeze thru the pump. You will need a new one.
