Driftwood132
Jan 22, 2014Explorer
See if the owner will send you pictures of the jacks and the set up of how the brackets are mounted . Someone here can explain how and what you will have to change . Its not a real big deal if the brackets are facing out from the camper along with the jacks. But if they are under the cab over then the brackets will have to be taken off and turned around. This is on a Atwood or Ricco Titan type of jacks. The bolt holes will work on either if its a newer type of jack. I hope someone will chime and explain better.
