More2Explore
Mar 03, 2015Explorer
The horizontals are supposed to be filled in a vertical position and should be vented in the vertical position prior to re-install to ensure you only get gas , not liquid which also helps avoid build-up on/in appliances.
Not advisable to fill while still in the vehicle as stated above.
44,027 PostsLatest Activity: Apr 19, 2019
