sleepy
Mar 03, 2015Explorer
More2Explore wrote:
The horizontals are supposed to be filled in a vertical position and should be vented in the vertical position prior to re-install to ensure you only get gas , not liquid which also helps avoid build-up on/in appliances.
Not advisable to fill while still in the vehicle as stated above.
Moretoexplore, I think that I am answering your concern.
Some of the horizontal tanks that are available have their valves on the sides... along with their gauges. They are only filled to 80% so there is room fot the propane to form a gas.... to prevent the liquid propane from getting to the applainces.
This is why I'd like to be able to use the exsisting slide out drawer... to access the valves, gauges, and hoses.
44,027 PostsLatest Activity: Apr 19, 2019
